Vehicle Turning Circle Design Equations and Calculator
Engineering and Design Applications
Vehicle Turning Circle Design and Engineering Equations and Calculators.
When a vehicle is cornering, each wheel describes a turning circle. The outer turning circle, or its radius, is the main subject of interest. The calculation is not precise because when a vehicle is cornering the perpendiculars through the centers of all wheels do not intersect at the curve center point (Ackermann condition). In addition, while the vehicle is moving dynamic forces will arise that will affect the cornering maneuver. However, the following formulae can be used for estimation purposes:
Calculator Preview: Vehicle Turning Circle Equations and Calculators
Distance Between steering axis
j = s - 2rO
Theorectical value of the outer steering angle
cotΒa0 = cotβi + j / Ikt
Steering angle deviation
ΒF = Βa - Βa0
Turning circle radius
rs = Ikt / sinΒa0 + rO - 50 ·ΒF
j = Distance between steering axles (mm)
Ikt = Wheelbase center to center (mm)
s = Track or whele to wheel center width (mm)
ro = Scrub radius (mm) the distance in front view between the king pin axis and the center of the contact patch of the wheel, where both would theoretically touch the road.
βi = Inner steering angle
βa = Outer steering angle
rs = Turning circule radius (mm)
βF = Steering deviation (deg)
'a0 = Theorectical value for outer steer angle
