Torsional Deformation Stress Hollow Elliptical Section Equation and Calculator
Torsional Deformation and Stress Hollow Elliptical Section Equations and Calculator. Hollow elliptical section, outer and inner boundaries similar ellipses
Preview
Torsional Deformation and Stress Eccentric Hollow Elliptical Section Calculator
q = ao / a = bo / b
Wall thickness is not constant
θ = ( T L ) / ( K G )
Shear Stress
τmax = 2 T / [ π a b2 ( 1 - q4 ) ] at end of monor axis on outer surface
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a, b = Diameter (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
