Tolerances Knurled Outside Diameters
Recommended Tolerances on Knurled Outside Diameters per. ANSI ASME B94.6
Tolerance
Class
Diametral Pitch
64
96
128
160
64
96
128
160
Tolerance on
Tolerance on
Work-Blank Diameter Before Knurling
I
+ 0.005
− 0.012
+ 0.004
− 0.010
+ 0.003
− 0.008
+ 0.002
− 0.006
± 0.0015
± 0.0010
± 0.0007
± 0.0005
II
+ 0.000
− 0.010
+ 0.000
− 0.009
+ 0.000
− 0.008
+ 0.000
− 0.006
± 0.0015
± 0.0010
± 0.0007
± 0.0005
III
+ 0.000
− 0.006
+ 0.000
− 0.005
+ 0.000
− 0.004
+ 0.0000
− 0.003
+ 0.0000
− 0.0015
+ 0.0000
− 0.0010
+ 0.000
− 0.0007
+ 0.0000
− 0.0005
Class I: Tolerances in this classification may be applied to straight, diagonal and raised diamond knurling where the knurled outside diameter of the work need not be held to close dimensional tolerances. Such applications include knurling for decorative effect, grip on thumb screws, and inserts for moldings and castings.
Class II: Tolerances in this classification may be applied to straight knurling only and are recommended for applications requiring closer dimensional control of the knurled outside diameter than provided for by Class I tolerances.
Class III: Tolerances in this classification may be applied to straight knurling only and are recommended for applications requiring closest possible dimensional control of the knurled outside diameter. Such applications include knurling for close fits.
Note: The width of the knurling should not exceed the diameter of the blank, and knurling wider than the knurling tool cannot be produced unless the knurl starts at the end of the work.
ASME B94.6 R2014 (1984)
