Thin Circular Open Tube Torsional Deformation and Stress Equation and Calculator
Torsional Deformation and Stress Thin Circular Open Tube of Uniform Thickness Section Equations and Calculator.
Preview
Torsional Deformation and Stress Hollow Thin Circular Open Tube of Uniform Thickness Calculator
K = (2/3) π r t3
θ = ( T L ) / ( K G )
Shear Stress Maximum
Along both edges remote from ends and assumes t is small compared with mean radius.
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
r = Radius (in, mm)
t = Thickness wall (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
