Temperature - Equivalent Conversion Calculators Menu
Degrees Celsius
Temperature scale that registers the freezing point of water as 0 degrees C and the boiling point as 100 degrees C under normal atmospheric pressure.
Degrees Fahrenheit
Temperature scale that registers the freezing point of water as 32 degrees F and the boiling point as 212 degrees F at one atmosphere of pressure
Degrees Kelvin
Temperature scale in which zero occurs at absolute zero and each degree equals one kelvin. Water freezes at 273.15 K and boils at 373.15 K.
Degrees Rankine
Absolute temperature using degrees the same size as those of the Fahrenheit scale, in which the freezing point of water is 491.69 and the boiling point of water is 671.69.
