Stress in Cylindrical Shell Equation and Calculator
Pressure Vessel Design and Engineering
Uniform internal or external pressure induces in the longitudinal seam two times larger unit stress than in the circumferential seam because of the geometry of the cylinder.
A vessel under external pressure, when other forces (wind, earthquake, etc. ) are not factors, must be designed to resist the circumferential buckling only . When other loadings are present, these combined loadings may govern and heavier plate will be require than the plate which was satisfactory to resist the circumferential buckling only.
The compressive stress due to external pressure and tensile stress due to internal pressure shall be determined by the for the equations:
Stresses in Cylindrical Shell Calculator:
Preview
Circumferential Joint
S1 = PD/4t
Longitundinal Joint
S2 = PD/2t
D = Mean diameter of vessel , inches
P= Internal or external pressure , psi
S1 = Longitudinal stress, psi
S2 = Circumferential (hoop) stress, psi
t = Thickness of shell, corrosion allowance excluded, inches
Example:
Given:
D = 96 inches
P= 15 psi
t = 0.25 inches
S1 = PD/4t = (15 x 96) / (4 x 0.25) = 1440 psi
S2 = PD/2t = (15 x 96) / ( 2 x 0.25) = 2880 psi
For towers under internal pressure and wind load the critical height above which compressive stress governs can be approximate
H = PD/32t
H = Critical Height
