Stress Hollow Rectangle Thin Wall Tube Torsion Equations and Calculator
Torsional Deformation and Stress Hollow Rectangle Thin Wall Tube Section Equations and Calculator.
Hollow Elliptical Section
Preview
Torsional Deformation and Stress Hollow Rectangle Thin Wall Tube Section Calculator
θ = ( T L ) / ( K G )
Shear Stress
Near the mid length of the short sides
Near the mid length of the Long sides
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a, b = Diameter (in, mm)
t = Thickness wall (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
