Step Thrust Plate Bearing Design Equation and Calculator
Machine Design Applications
Bearing Engineering and Design
Step Thrust Plate Bearing Design Equation and Calculator:
Flat Thrust Plate Bearing Design Formulas and Calculator
Basic Element of thrust bearing
Preview: Step Thrust Plate Bearing Design Calculator
Thrust Bearing Typical Loads
Surface
Loads
Lbs/in2
Max Loads
Lbs/in2
Parallel surface
< 75
< 150
Step Surface
200
500
Tapered Land Surface
200
500
Tilting Pad Surface
200
500
Reproduced with permission from Wilcock and Booser, Bearing Design and Applications, McGraw-Hill Book Co., Copyright © 1957.
General Design Parameters: Recommended optimum proportions, a = b, b2 = 1.2b1, and e = 0.7h.
External diameter formula:
D2 = ( ( 4 W ) / ( ( π Kg p ) + D12 )1/2
W = applied load, pounds
Kg = fraction of circumference occupied by pads; usually, 0.8
p = bearing unit load, psi
Radial pad width, given in inches
a = (1/2) ( D2 + D1 )
Number of bearing pads, i. Assume that the oil groove width, s = 0.062 inch is minimum
i = B / ( a + s ) = nearest even number
i as the nearest even number to that calculated.
Length of bearing pad given in inches
b = B / i - s
Pitch line velocity, given in fpm
U = ( B N ) / 12
where, N - rpm
Film thickness, given in inches
h = [ ( 2.09 x 10-9 i a 3 U Z ) / W ]0.5
Depth of step, given in inches
e = 0.7 h
Friction power loss, given in HP
Pf = ( 7.35 x 10-13 i a2 U2 Z ) / h
Pad step length, distance is on the pitch line, from the leading edge of the pad to the step. Given in inches.
b2 = ( 1.2 b ) / 2.2
Hydrodynamic oil flow, given in gpm
Q = 6.65 x 10-4 i a h U
Temperature rise, given in degrees F
Δt = ( 42.4 Pf ) / ( c Q )
Should temperature rise to be excessive, this is an indication that the flow is insufficient
Notation:
a = radial width of pad, inches
b = circumferential length of pad at pitch line, inches
b2 = pad step length
B = circumference of pitch circle, inches
c = specific heat of oil, Btu/gal/°F
D = diameter, inches
e = depth of step, inch
f = coefficient of friction
g = depth of 45° chamfer, inches
h = film thickness, inch
i = number of pads
J = power loss coefficient
K = film thickness factor
Kg = fraction of circumference occupied by the pads; usually, 0.8
l = length of chamfer, inches
M = horsepower per square inch
N = revolutions per minute
O = operating number
ps = oil-supply pressure, psi
Pf = friction horsepower
Q = total flow, gpm
Qc = required flow per chamfer, gpm
Qoc = uncorrected required flow per chamfer, gpm
QF = film flow, gpm
s = oil-groove width
∆t = temperature rise, °F
U = velocity, feet per minute
V = effective width-to-length ratio for one pad
Yg = oil-flow factor
Yl = leakage factor
YS = shape factor
Z = viscosity, centipoises
α = dimensionless film-thickness factor
δ = taper
ξ = kinetic energy correction factor
  • Machinery's Handbook, 29th Edition
  • Understanding Journal Bearings, Malcolm E. Leader, P.E. Applied Machinery Dynamics Co.
  • Theory and Practice of Lubrication for Engineers by Dudley D. Fuller, Wiley and Sons, 1984, ISBN 0- 471-04703-1
  • Bearing Design and Application by Donald F. Wilcock and E. Richard Booser, McGraw Hill, 1957, 195, LC number 56-9641
