Standard Atmospheric Data for Altitude and Temperature for U.S
Fluids Engineering and Design Data
Hydraulics and Pneumatics Design and Engineering
Standard Atmospheric Data for Altitude and Temperature - See Tables below....
U.S. Standard Pressure at altitude may be calculated from:
Equation 1
p = 14.696 · ( 1 - 6.8754 x 10-6 Z )5.2559
The formula for temperature as a function of altitude is:
Equation 2
t = 59 - 0.00356620 · Z
Z = altitude, ft
p = barometric pressure, psia
t = temperature, °F
Equations (1) and (2) are accurate from –16,500 ft to 36,000 ft. For higher altitudes, comprehensive tables of barometric pressure and other physical properties of the standard atmosphere, in both SI and I-P units, can be found in NASA (1976).
Table 1: Standard U.S. Atmosphere Pressure and Temperature Imperial Units
Altitude, ft
Temperature, °F
Pressure,
psia
–1000
62.6
15.236
–500
60.8
14.966
0
59.0
14.696
500
57.2
14.430
1,000
55.4
14.175
2,000
51.9
13.664
3,000
48.3
13.173
4,000
44.7
12.682
5,000
41.2
12.230
6,000
37.6
11.778
7,000
34.0
11.341
8,000
30.5
10.914
9,000
26.9
10.506
10,000
23.4
10.108
15,000
5.5
8.296
20,000
–12.3
6.758
30,000
–47.8
4.371
Table 21: Standard U.S. Atmosphere Pressure and Temperature SI Units
Altitude, m
Temperature, °C
Pressure,
N/m2
–304.8
17.0
105048.5
-152.0
16.0
103186.9
0
15.0
101325.3
152.4
14.0
99491.3
304.8
13.0
97733.2
609.6
11.1
94209.9
914.4
9.1
90824.6
1219.2
7.1
87439.3
1524.0
5.1
84322.9
1828.8
3.1
81206.4
2133.6
1.1
78193.4
2438.4
-0.83
75249.4
2743.2
-2.83
72436.3
3048.0
-4.78
69692.2
4572.0
-25.96
57198.9
6096.0
-24.61
46594.7
9144.0
-44.33
30136.9
The standard atmosphere gives a standard of reference for estimating properties at various altitudes. At sea level, standard temperature is 59°F; standard barometric pressure is 14.696 psia or 29.921 in. Hg. Temperature is assumed to decrease linearly with increasing altitude throughout the troposphere (lower atmosphere), and to be constant in the lower reaches of the stratosphere.
The lower atmosphere is assumed to consist of dry air that behaves as a perfect gas. Gravity is also assumed constant at the standard value, 32.1740 ft/s2.
  • Adapted from NASA (1976).
