Extension Spring Rate Constant Calculator
Springs Resource Menu
Extension Spring Dimensional Data
This calculator will calculate (estimate) the Spring Rate (k) of a extension spring. Spring rate is best determined by test and measurement techniques.
See the equations behind this calculator:
Extension Spring Rate "k" Constant Formula
Extension Spring Constant Calculator
Design Variables
Modulus of Rigidity (G) =
Wire Diameter, inches (d) =
Number of Active Coils (n) =
Mean Coil Diameter, inches (D) =
Results
Spring Constant (k) =
Automatic recalculation
Extension Spring Design Suggestions
