Sheet Metal Socket Driver Clearance Equations and Calculator
Sheet Metal Design and Engineering
Sheet Metal Two Flanges Overlap Clearance Width Socket Design Equations and Calculator.
Sheet Metal Two Flanges Overlap Clearance Width Design
Flange Width (FM) = SB + PT + EMT + C / 2 + EM
or
Flange Width (FM) = SB + PT + S / 2 + EM
** Whichever is largest **
FM = Flange Width (in, mm),
EMT = Edge Margin Tolerance: Typical (.05 in, 1.27 mm),
C = Fastener Head Diameter (in, mm),
SB = Setback Radius on Outside Wall (in, mm),
PT = Tolerance of Part Radius (in, mm),
S = Outside Diameter of Ratchet Socket (in, mm),
EM = Flange Edge to Fastener Center (in, mm)
