Scissor Lift Jack Force Center Load Calculator
Scissor Lift Companies
Open webpage with mathematical proof (Equations and Calculators updated: April 20, 2012)
Equations and proof
Open: Scissor Lift Jack Force Center Load Proof Equations
A scissors lift uses linked, folding supports in a criss-cross 'X' pattern, known as a pantograph. The extension is achieved by applying pressure to the outside of a set of supports located at one end of the lift, elongating the crossing pattern. This can be achieved through hydraulic, pneumatic, mechanical or simply muscular means.
It may require no power to return to its original position, but simply a release of the original pressure.
