Right-Angle Isosceles Triangle Stress and Deflection Equation and Calculator
Right-Angle Isosceles Triangle; all edges simply supported with uniform loading over entire plate Stress and Deflection Equation and Calculator.
Equilateral Triangle Plate
Uniform Loading over entire plate ![]() |
Stress max
Stress x max.
Deflection
q = Applied load (force) (lbs/in2)
E = Modulus of Elasticity (lb/in2)
a = Height of plate (in)
t = Plate thickness (in)
σ = stress, (lbs/in2)
y = Deflection (in)
