Right Vertical Concentrated Angular Displacement Applied Equations and Calculator
Frame Deflections with Concentrated Angular Displacement Applied Right Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Angular Displacement Applied Applied to Right Vertical Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
LPh = θo ( l2 - a )
LPm = 0
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
