Re-Bar Channel Unequal Length Legs Center Line Length Equation and Calculator
Civil Engineering and Design
Engineering Analysis Menu
Standard ReBar Shapes Formula and Calculator
Re-Bar Channel 90° Degree Bend Unequal Length Legs with Center Line Length Equation and Calculator
Rebar Ninety (90°) Degree Bend Equation and Calculator
L = A + B + C - r - 2 d
L = Center line length (in, mm)
A = Leg length (in, mm)
B = Leg length (in, mm)
C = Leg length (in, mm)
d = Rebar diameter (in, mm)
r = Rebar radius (in, mm)
Note: Keep all units consistant, typical units shown.
