Reaction and Deflection Case 5N Elastic Frame Roark's Formulas for Stress and Strain Formulas and Calc
Reaction and deflection formulas for in-plane loading of elastic frame with mounting ends fixed and Concentrated Angular Displacement on the Right Vertical Member Frame formulas and calculator. Roark's Formulas for Stress and Strain, Seventh Edition, Table 8.2 reference loading number 5N.
The formulas given assume the frames to have rigid corners; however, corrections can be made easily once the rigidity of a given corner design is known by making use of the concentrated angular displacement loading with the displacement positioned at the corner.
Loading Configuration
Preview: Frame Deflections with Concentrated Angular Displacement on the Right Vertical Member Frame Calculator
Deformation equations:
Loading CHH
Loading CHV
Loading CHM
Loading CVV
Loading CVM
Loading CMM
Loading terms for Concentrated moment on the right vertical member frame member:
Loading terms for Concentrated angular displacement on the left vertical member frame member
Where used:
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
