Power Conversions - Equivalents Calculator
Engineering Calculators | Conversions & Constants
This calculator will determine the power equivalents of the indicated units. Enter the value you wish to convert, selsct the radio button on the "From" and the "To: then select "Click for Conversion".
Type the number you wish converted here:
Then click radio buttons for desired conversion:
Metric hp
Kw
Ton (Refrigeration)
joule/sec
Ft-lb/sec
Kcal/sec
Btu/sec
To: Hp
Metric Hp
Kw
Ton (Refrigeration)
joule/sec
Ft-lb/sec
Kcal/sec
Btu/sec
