Plate Loading Uniformly Decreasing from Fixed Edge Stress and Deflection Equation and Calculator
Flat Rectangular Plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to free edge Stress and Deflection Equation and Calculator.
Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness
Rectangular plate; one edge fixed, opposite edge free, remaining edges simply supported loading Uniformly decreasing from fixed edge to free edge.
Preview: Flat Rectangular Plate Uniform Force over Entire Plate Two Long Edges Fixed, Two Short Edges Simply Supported Calculator
opposite edge free,
remaining edges simply supported.
from fixed
edge to free edge.
Uniformly decreasing load
Stress Maximum at center of fixed edge:
Stress Maximum and R = γqb
Symbols used:
q = Applied Load or Force to Flat Area of Plate (N/m2, lbs/2)
v = Poisson’s ratio (assumed to be 0.2)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
σ = stress, (N/m2, lbs/in2)
R = Reaction force per unit length (N/m, lbs/in) normal to the plate surface exerted by the boundary support on the edge of the plate.
β = Constant From Table A
γ = Constant From Table A
Table A
a/b
0.25
0.50
0.75
1.0
1.5
2.0
3.0
β
0.037
0.120
0.212
0.321
0.523
0.677
0.866
γ
0.159
0.275
0.354
0.413
0.482
0.509
0.517
