Pinned Shaft Deflection, Stress Equation and Calculator
Torque Applied Deformation and Stress of a Pinned Shaft Equations and Calculator
Preview
Torque Applied Deformation and Stress of a Pinned Shaft Section Calculator
K = 2Cr4
Varies with a / r as follows
For:
0   ≤   a / r ≤   0.5
θ = ( T L ) / ( K G )
Shear Stress Maximum
At M:
Torque Applied Deformation and Stress of a Shaft with Four Splines Section Calculator
Where B varies with a / r as follows:
for 0.1 ≤ a / r ≤ 0.5
θ = angle of twist (radians),
r, a = radius (in, mm),
