Open Tube of Uniform Thickness Section Torsional Deformation and Stress Equation and Calculator
Torsional Deformation and Stress Any Thin Open Tube of Uniform Thickness Section Equations and Calculator.
Preview
Torsional Deformation and Stress Any Thin Open Tube of Uniform Thickness Calculator
K = (1/3) U t3
U ¼length of median line, shown dashed
θ = ( T L ) / ( K G )
Shear Stress Maximum
Along both edges remote from ends and assumes t small compared wtih least radius of curvature of median line.
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
U = Center Line Length (in, mm)
t = Thickness wall (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
