Machining Speeds and Feeds Calculator
Equations and Explanation Behind this Calculator
This calculator will determine speeds and feed rates for machining operations on mill or lathes.
Cutting speeds are usually given in feet or meters per minute and these speeds must be converted to spindle speeds, in revolutions per minute, to operate the machine.
After changing variables Click in this area space or "Recalculate" to see results.
Calculate Spindle Speed Variables
Units metric inches
Cutting Speed V (m/min or fpm)
Diameter D (mm or inches)
Results
Spindle Speed rpm (m/min or rpm)
Calculate Cutting Speed Variables
Units metric inches
Results
Automatic recalculation
