Length of Screw Thread Engagement Calculator and Table
Fastener, Bolt and Screw Design Torque and Force Calculations
ISO Hardware Engineering Data
ANSI Hardware Engineering Data
Length of Screw Thread Engagement per. ISO 965-1 Calculator, Formula and Table
Length of engagement of mating threads is selected to utilize full tensile strength of a bolt prior to shearing nut threads. Other applications may require internal thread shear prior to failure of theoretically threaded part
For the calculation of the limits of the normal length of thread engagement in Table 1,
the following formulas have been used and their values rounded.
For each pitch, P, within a certain diameter range, d has been set equal to the smallest diameter within the table range.
Normal LE min. = 2.24 · P · d0.2
Normal LE max. = 6.7 · P · d0.2
Eq. 3
Threads per mm = 1 / P
Where
d = Basic Major Diameter, mm
P = Pitch distance single thread, mm
The length of screw thread engagement given below (Table 1), have been calculated from formulas and then rounded off to the nearest values in the R40 series of preferred numbers in accordance with ISO 3 for the three decimal places required. If a fourth decimal place results, it is further rounded.
Table 1 Length of Screw Thread Engagement Tabulated
d
Over - up to and including
mm
Pitch
P
mm
Length of Engagement
Normal LE
Rounded
Rounded to nearest mm
(Less than is considered short)
(More than is considered long)
1.5 - 2.8
0.2
0.5
1.5
0.25
0.6
1.9
0.35
0.8
2.6
0.4
1
3
0.45
1.3
3.8
2.8 - 5.6
0.35
1
3
0.5
1.5
4.5
0.6
1.7
5
0.7
2
6
0.75
2.2
6.7
0.8
2.5
7.5
5.6 - 11.2
0.75
2.4
7.1
1
3
9
1.25
4
12
1.5
5
15
11.2 - 22.4
1
3.8
11
1.25
4.5
13
1.5
5.6
16
1.75
6
18
2
8
24
2.5
10
30
22.4 - 45
1
4
12
1.5
6.3
19
2
8.5
25
3
12
36
3.5
15
45
4
18
53
4.5
21
63
45 - 90
1.5
7.5
22
2
9.5
28
3
15
45
4
19
56
5
24
71
5.5
28
85
6
32
95
90 - 180
2
12
36
3
18
53
4
24
71
6
36
106
8
45
132
180 - 355
3
20
60
4
26
80
6
40
118
8
50
150
References
American Society of Mechanical Engineers Standard ASME B1.13M-2005 (Revision of the ASME B1.13M-2001)
