Least Square Fitting Algorithm Calculator and Graphing Tool
Least Square Fitting Algorithm to Fit a Polynomial Curve to a Data Set Calculator and Graphing Tool.
Preview Least Square Fitting Calculator and Graphing Tool
Procedure
This model fits a polynomial curve to a data set. Users can add points (up to a limit) by clicking within the plotting panel. Add data to the panel and then adjust the parameters of the polynomial y = f(x), in order to obtain a good fit using the a, b, c, d, and e parameters. Use the best fit button to compare your fit to the the best possible polynomial fit.
Numeric model element
This model demonstrates how to use the Numeric model element (see the Elements panel of the model) to solve the system of linear equations required for the least squares approximation.
function is
where {fj(x)} are a basis of linear independent functions: {1,x,x2,x3,...,xm} and {cj } are the coefficients.
The objective is to minimize the sum:
linear independent functions .
To this end, we have to differentiate with respect to ci , and equate to zero:
equation
Obtaining the follow system:
integral
where (a,b)d are defined as:
forumula .
Credits:
Francisco Esquembre
Wolfgang Christian
Released under a Creative Commons Attribution Non-Commercial-Share license.
