Fritzsche Formula at Standard Conditions Equation and Calculator
Fritzsche Formula for Pressure Change at Standard Conditions Equation and Calculator
The Fritzsche formula uses the friction factor f calculated from the following equation:
Equation 1
F = 0.02993 ( Ts / ( Ps Qs ) 1/7
where:
f = friction factor
Ts = temperature at standard conditions, °R
Ps = pressure at standard conditions, psia
Qs = volume flow rate at standard conditions, SCFM
The Fritzsche formula for pressure drop then becomes
Equation 2
ΔP = ( 9.8265 x 10-4 ) T L / ( P d5 ) ( Ps Qs / Ts )1.857
where:
ΔP = pressure drop, psi
L = pipe length, ft
d = pipe inside diameter, in
T = airflow temperature, °R
P = average air pressure, psia
Ts = temperature at standard conditions, ◦R
And in terms of flow rate and the upstream and downstream pressures, this becomes
Equation 3
Qs = 29.167 Ts / Ps [ ( P12 - P22 ) d5 ) / ( T L )] 0.538
where:
Qs= volume flow rate at standard conditions, SCFM
Ps
P1
= upstream pressure, psia
P2
= downstream pressure, psia
L
= pipe length, ft
d
The preceding formulas can be used for the flow of air at standard conditions and any flowing temperatures. When standard conditions of 14.7 psia and 60°F are used along with a flowing temperature of 60°F, the preceding formulas can be simplified as follows:
Equation 4
ΔP = L Qs1.857 / ( 1480 P d5 )
where:
L = pipe length, ft
Qs = volume flow rate at standard conditions, SCFM (see equation 5)
Equation 5
Qs = 1 / 35 [ ( P12 - P22 ) d5 ) / L ]0.538
where:
P1 = upstream pressure, psia
P2 = downstream pressure, psia
L = pipe length, ft
Where air pressures are low and close to the atmospheric pressure such as in ventilating work and in airflow through ducts, we can modify the Fritzsche formula to calculate the pressure drops in in H2O. Since 1 in of water column is equal to 0.03613 psi, the pressure loss can be expressed as follows:
Equation 6
h = L Qs1.857 / ( 785 d5 )
where h is the pressure drop measured in in H2O.
Equation 7
Qs = ( 785 h d5 / L )0.538
  • Piping Calculations Manual,
    E. Shashi Menon
    SYSTEK Technologies, Inc
