Frame Deflection Concentrated Vertical on Member Equations and Calculator.
Frame Deflections with Concentrated Load Applied to Vertical Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Load Applied to Vertical Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
LPH
LPM
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
