Formed Sheetmetal Design Clearances Equations and Calculator
Sheet Metal Design and Engineering
Sheet Metal Two Flanges with Vertical Member Clearance Width Design Equations and Calculator.
Flange Width Basics
Flange Width (FM) = EM + EM2 + PT
or
Flange Width (FM) = SB + EMT + C / 2
Whichever is largest
FM = Flange Width (in, mm),
EMT = Edge Margin Tolerance: Typical (.05 in, 1.27 mm),
C = Fastener Head Diameter (in, mm),
PT = Edge to Bend Radius (in, mm),
SB = Setback Radius on Outside Wall (in, mm),
EM = Flange Edge to Fastener Center (in, mm)
EM2 = Flange Edge to Fastener Center (in, mm)
