Flat spring cantilevered design triangular geometry equations and calculator
Beam Stress Deflection Equations and Calculators
Spring Design Equations and Calculators
Flat spring design equations and calculator: The equations are based on standard beam formulas where the deflection is small.
Flat spring cantilevered design triangular geometry equations and calculator.
Deflection:
eq. 1
F = 6 P L3 / E b t3
eq. 2
F = Sb L2 / E t
Load:
eq. 3
P = Sb b t2 / 6 L
eq. 4
P = E b t3 F / 6 L3
Stress, Bending:
eq. 5
Sb = 6 P L / b t2
eq. 6
Sb = E t F / L2
Thickness, Spring:
eq. 7
t = Sb L2 / E F
eq.8
t = ( 6 P L3 / ( E b F ) )(1/3)
P = Load, (lbs),
L = Active length subject to deflection (inches),
b = Widest width of spring (in),
E = Modulus of Elasticity in Tension, (lbs/in2),
t = Thickness, (in),
Sb = Stress, bending (lbs/in2),
F - Deflection, for on active section (in)
Machinery Handbook, 27th edition
