Flat Rectangular Plate Uniform loading Stress and Deflection Equations and Calculator
Flat Rectangular Plate; two long edges simply supported, two short edges fixed Uniform loading over entire plate Stress and Deflection Equation and Calculator.
Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness
Rectangular plate; two long edges simply supported, two short edges fixed Uniform loading over entire plate
Preview: Flat Rectangular Plate Uniform Force over Entire Plate Three Edges Simply Supported Calculator
Stress Maximum at center of shorter edge:
Deflection at center:
Symbols used:
E = Modulus of Elasticity (N/m2, lbs/2)
q = Applied Load or Force to Flat Area of Plate (N/m2, lbs/2)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
σ max = maximum stress, (N/m2, lbs/in2)
ymax = Maximum deflection (m, in)
α = From Table A
β = From Table A
Table A
a/b
1
1.2
1.4
1.6
1.8
2.0
β
0.4182
0.4626
0.4860
0.4968
0.4971
0.4973
0.500
α
0.0210
0.0243
0.0262
0.0273
0.0280
0.0283
0.0285
