Flat Rectangular Plate Uniform Force Entire Plate Equations and Calculator
Flat Rectangular Uniform over entire plate plus uniform over entire plate plus uniform tension P lb=linear in applied to all edges Stress and deflection Equation and Calculator.
Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness
Preview: Flat Rectangular Plate Uniform Force over entire plate Calculator
Stress Maximum (Equations for σa and σb are stresses due to bending only;):
Stress Maximum Including Direct Stress and σa
+ P/t |
+ P/t |
Where α βx and βy depend on ratios a / b and P / PE where:
Deflection:
Symbols used:
E = Modulus of Elasticity (N/m2, lbs/2)
q = Applied Load or Force to Flat Area of Plate (N/m2, lbs/2)
P = Tension or Compression to Short Edges (N/m, Lbs/in)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
σ max = maximum stress, (N/m2, lbs/in2)
ymax = Maximum deflection (m, in)
α = From Table A
βx = From Table A
βy = From Table A
Table A (Click on Table to enlarge in Pop-up Window)
