Double-Riveted Lap-Joint Formulas and Calculator for Stress
Applications and Design
Stress, Deflections and Structural Analysis
Double-Riveted Lap-Joint Formulas and Calculator for Stress and Strength Design.
Double-Riveted Lap-Joint Formulas for Stress and Strength Design.
Preview
The efficiency of a riveted joint is equal to the strength of the joint divided by the strength of the un riveted plate, expressed as a percentage.
Resistance to shearing two rivets:
Rs = 2 π d2Ss / 4
Resistance to tearing between two rivets:
Rt = ( p - D) t St
Resistance to crushing in front of two rivets:
Rc = 2 d t Sc
The safe tensile load L based on single shear of the rivets:
L = n Ar Ss
The safe tensile load L based on bearing stress:
L = n Ab Sc
The safe load L based on the tensile stress:
L = Ap St
Efficiency of Design
η = [(safe tensile load L based on single shear of the rivets) / ( l t St) ] 100
Rs = Resistance to shearing (lbs)
Rt = Resistance to tearing plate between rivets (lbs)
Rc = Resistance to crushing rivet or plate (lbs)
L = Safe Tensile Load (lbs)
η = Strength of Joint / Strength of Un-riveted plate (%)
d = diameter of holes (in)
t = thickness of plate (in)
D = Diameter of the rivet (in)
tc = thickness of cover plates (in)
p = pitch of inner row of rivets (in)
P = pitch of outer row of rivets (in)
Ss = shear stress for rivets (lbs/in2)
St = tensile stress for plates (lbs/in2)
Sc = compressive or bearing stress for rivets or plates (lbs/in2)
Reference Machinery Handbook, 23rd Edition
