Counter & Parallel Flow Heat Exchanger Tube Length Calculation
  Input data in YELLOW
Update and Reset funtions at bottom of page.
HEAT-EXCHANGERS-2
Heat transfer, Q = U*A*∆Tm
Plane wall heat transfer coefficient, U = 1 / (1/ho + L/K + 1/h1
Cylindrical wall heat transfer coefficient, U = 1 / (1/hi + [RoLn(Ro/Ri)]/K + Ri/Ro)
  i and o refer to inside and outside tube surfaces.
Large temperature difference, ΔTbc = Ta - Td
ΔTbc = From Input Data below.
Small temperature difference, ΔTad = Tb - Tc
ΔTad = From Input Data below.
Logarithmic mean temp. difference, ΔTm = (ΔTbc - ΔTad)/ln(Tbc/ΔTad)
Answer: ΔTm = deg C
  The added resistance to heat transfer caused by corrosion is called fouling.
Fouling factor, R ranges between 0.0005 and 0.002. See manufactures data.
Fouling factor, R = (1/Udirty) - (1/Uclean)
Forced Convection - in Coiled Tube Heat Exchangers
Turbulent flow in coiled tube. Input Data
Temp. of Fluid (Liquid) flowing in, Ta = deg C
Temp. of Fluid (Liquid) flowing out, Tb = deg C
Tc = deg C
Td = deg C
Tube inside diameter, Di = mm
Tube outside diameter, Do = mm
Velocity of Fluid (Liquid) in tube, V = m / s
  Water properties at temperature Tb deg C from the table above:
Fluid (Liquid) density, ρ = kg / m^3
Cp = k*J/kg*K
Fluid (Liquid) dynamic viscosity, μ = kg / m*s
Fluid (Liquid) conductivity, k = W / m*K
Prandtl number, Pr = -
Factor, n =
  Results
Fluid (Liquid) bulk temperature, Tb = (Tin + Tout) / 2 deg C
Answer: Tb = deg C
Reynolds Number, Re = V*D / ν
or, Re = V*D*ρ / μ
Answer: Re = Turbulent Re >4000
Convective heat transfer coefficient, h = 0.023*(Re^.8)*(Pr^n)*(k/d)
S.I. Answer: h = W / m^2*K
U.S. Answer: h = (W/m^2*K)/5.5956 Btu/hr-ft^2*F
U.S. Answer: h = Btu/hr-ft^2*F
S.I. Answer from above: h = W / m^2*K
Large temperature difference, ΔTbc = Tb - Tc
Answer: ΔTbc= deg C
Small temperature difference, ΔTad = Ta - Td
Answer: ΔTad = deg C
Logarithmic temperature difference, ΔTm = (ΔTbc - ΔTad)/ln(Tbc/ΔTad)
Answer: ΔTm = deg C
Overall heat transfer coefficient = Uo
Heat flow rate, Q = Uo*A*ΔTm
Heat flow rate thru inside tube wall, Qi = Uo*π*di*L*ΔTm
Heat flow rate thru outside tube wall, Qo = Uo*π*do*L*ΔTm
Uo = h *Ai / Ao
Tube inside area, Ai = π*di*L
Tube outside area, Ao = π*do*L
Overall heat transfer coefficient, Uo = h *di / do
Answer: Uo = W / m^2*K
Cp = Cp*1000 1000*J/kJ
Answer: Cp = J/kg*K
  Disregarding tube fouling, determine the tube length required:
  The tube length required, L = ρ*V*(di)^2*Cp*(Tout -Tin) / (4*Uo*do*ΔTm)
Answer: L = m
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
