Column Loading Elastic Case 1b Formulae and Calculator
Column Loading and Elastic Stability Formulae and Calculator Case 1b
Stepped straight bar under end load P1 and intermediate load P2; both ends pinned
Preview: Column Loading and Elastic Stability Calculator Case 1b
NOTATION:
P1 = Load (force) (lbs, N);
P2 = Load load (force) (lbs, N);
p' = critical unit load (force per unit length), (lbs, N);
T' = critical torque (force-length A.R.) (in-lbs, N-mm);
M' critical bending moment (force-length);
l = Length of bar (in, mm),
K1 = Derived from ratios as follows (see table):
1.) ( E2 I2 ) / ( E1 I1 )
2.) a / l
3.) P2 / P1
Formulae:
P'1 = ( K1 π2 E1I1 ) / l2
