Column Loading and Elastic Stability Case 2a Formulae and Calculator
Editing Content Field: 'Article text' For Listing: Column Loading and Elastic Stability Case 2a CSS file in use: /engineering/article.css | Change _
Column Loading and Elastic Stability Formulae and Calculator Case 2a
Stepped straight bar under end load P1 and intermediate load P2; both ends fixed
Preview: Column Loading and Elastic Stability Calculator Case 2a
NOTATION:
P1 = Load (force) (lbs, N);
P2 = Load load (force) (lbs, N);
p' = critical unit load (force per unit length), (lbs, N);
T' = critical torque (force-length A.R.) (in-lbs, N-mm);
M' critical bending moment (force-length);
l = Length of bar (in, mm),
K2 = Derived from ratios as follows (see table):
1.) ( E2 I2 ) / ( E1 I1 )
2.) a / l
3.) P1 / P2
Formulae:
P'2 = ( K2 π2 E1I1 ) / l2
