Circular Shaft Opposite Sides flattened Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Circular shaft with opposite sides flattened Equations and Calculator.
Preview
Torsional Deformation and Stress Circular shaft with opposite sides flattened Calculator
h = r - w
K = 2Cr4 where C varies with h / r as follows:
For two flat sides 0 ≤ h / r ≤ 0.8
C = .7854 - 0.4053 (h / r) - 3.5810 (h / r)2 + 5.2708 (h / r)3 - 2.0772 (h / r)4
θ = ( T L ) / ( K G )
Shear Stress
For 0 ≤ h / r ≤ 0.6
B = 0.6366 + 2.5303 (h / r) - 11.157 (h / r)2 + 49.568 (h / r)3 - 85.886 (h / r)4 + 69.849 (h / r)5
τmax = T B / r3
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
r = Radius (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
