Circular Ring no. 9 Roarks Formulas for Stress and Strain Equations and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #9.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #9.
![]() Circular Ring Loading #9 |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #9
θ ≥ π / 2
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
LTM = w R2 / 6 s ( z - s )3 〈 x - θ 〉0
LTN = w R z ( z - s )2 〈 x - θ 〉0
LTv = w R u / 2 s ( z - s )2 〈 x - θ 〉0
〈 x - θ 〉0
NA = (- w R s3 ) / ( 12 π )
VA = 0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
Change of length of Circular Ring
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
〈 x - θ 〉0
if x < 0, 〈 x - θ 〉0 =0;
if x > 0, 〈 x - θ 〉0 =1;
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 9, loading, and load terms.
