Circular Ring Analysis with equal radial forces Equations and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #7.
Ring under any number of equal radial forces equally spaced.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #7.
![]() Circular Ring Loading #7 |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #7
Formulas for moment, hoop load, radial shear and deformations Ring under any number of equal radial forces equally spaced.
For 0 < x < θ
Moment
M = [ W R ( u/s - k2 / θ ) ]
Hoop Stress
N = W u / ( 2 s )
Radial Shear
V = - ( - W z ) / ( 2 s)
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
At each load position
Radial displacement at each load point = ΔRB
Radial displacement at x = 0.20, ... = ΔRA
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 5, loading, and load terms.
