Circular Ring Analysis No 18 Roarks Formulas for Stress and Strain Equations and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #18.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #18. Formulas for moments, loads, and deformations and some selected numerical values.
Circular Ring Loading #18
Circular Ring Dimensional
Properties
Resultant moment, hoop load, and radial shear
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #18
θ ≥ π / 2
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
Unit loads (force per unit of circumferential length)
Poisson’s ratio
load terms
load terms
load terms
Unit step function defined by use of ⟨ ⟩, See explanation at bottom of page.
⟨ x - θ ⟩0 and/or ⟨ x - φ ⟩0
Moment about A
Shear function
Function
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
v = unit loads (force per unit of circumferential length) (lbsf/in, N/m);
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
⟨ x - θ ⟩0
if x < 0, ⟨ x - θ ⟩0 =0;
if x > 0, ⟨ x - θ ⟩0 =1;
At x = θ the unit step function is undefined just as vertical shear is undefined directly beneath a concentrated load. The use of the angle brackets ⟨ ⟩ is extended to other cases involving powers of the unit step function and the ordinary function ⟨ x - a ⟩n
Thus, the quantity ⟨ x - a ⟩n ⟨ x - a ⟩0 is shortened to ⟨ x - a ⟩n and again is given a value of zero if x < a and is ( x-a )n if x > a.
Table of Constants (Click for larger view)
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 18, loading, and load terms.
