AGMA WormGear Equations For Rating Factors
Gear Engineering and Design
Mechanics and Machine Design and Engineering
AGMA Worm and Spur Gear Design Equations and Calculators
AGMA Wormgear Equations For Rating Factors
Values for the ratio correction factor, the velocity factor, and materials factors can be found from tables provided in the ANSI/AGMA 6034-B92 standard. The following equations for the ratio correction factor, the velocity factor, and materials factors provide approximations to the values given in the tables.
The ratio correction factor Cm is a function of the gear ratio, mG.
For 3 ≤ mG ≤ 20
Cm = 0.02 ( -m2G + 40mG - 76)0.5 + 0.46
For 20 < mG ≤ 76
Cm = 0.0107 ( -m2G + 56mG + 5145)0.5
For mG > 76
Cm = 1.1483 - 0.0065m G2
Velocity correction factor Cv is a function of the sliding velocity at the mean worm diameter, Vt.
For 0 < Vt ≤ 3.556 m/s
Cv = 0.659 e-0.2165Vt
For 3.556 < Vt ≤ 15.24 m/s
Cv = 0.652 Vt-0.571
For Vt > 15.24 m/s
Cv = 1.098 Vt-0.774
Note: (Vt m/s ) x 196.5 = ( Vt ft/min )
Friction, µ is a function of the sliding velocity at the mean worm diameter, Vt.
For Vt = 0,
µ = 0.15
For 0 < Vt ≤ 0.0508 m/s
µ = 0.124 e( -2.233z )
where: z = Vt0.645
Vt > 0.0508 m/s
µ = 0.103 e( -1.185z )
where: z = Vt0.45
The materials factor Cs depends on the method of casting.
For Sand Casting
For center distance (Radius) C ≤ 76.2 mm, an initial estimate for the materials factor can be obtained from:
Cs = 720 + 0.000633C3
This value can be compared to the values obtained for the relevant means of casting, as indicated by the following relationships and the smaller value used.
For sand cast gears then:
for dm ≤ 63.5 mm
Cs = 1000
for dm > 63.5 mm
Cs = 1856.104 - 476.5454 log10 dm
For chill cast bronze gears:
for dm ≤ 203.2 mm
Cs = 1000
for dm > 203.2 mm
Cs = 2052.011 - 455.8259 log10 dm
For centrifugally cast gears:
for dm ≤ 635 mm
Cs = 1000
for dm > 635 mm,
Cs = 1503.811 - 179.7503 log10 dm
ANSI/AGMA 6034-B92, Practice for Enclosed Cylindrical Wormgear Speed Reducers and Gearmotors, Annex C Fomulas for rating factors.
© Copyright 2000 - 2022, by Engineers Edge, LLC www.engineersedge.com
