V and Flat Belt Design Guide, Equations, and Information
V and Flat Belt Design and Engineering Data
Belt Tensions, Pretensions, Torques, Power and Configurations
Description Equation
Torque transmitted by a belt Torque transmitted by a belt
Rated power of belt Rated power of belt
Tension of flat belt Tension of flat belt
Tension of V-belt Tension of V-belt
Centrifugal loading Centrifugal loading
Belt length (open) Belt length (open)
Belt length (closed) Belt length (closed)
  • Angle of contact
    Note:
  • Use (+) for large pulley and X-belts
  • Use (-) small pulley
  • Angle in radians
Angle of contact
Angle in radians
Variable Declarations
P = tension in belt (1-tight, 2-slack)
r = pulley radius
T = Torque (in-lb)
w = rpm
f = coefficient of friction (leather = 0.3, rubber = 0.25 Flat belt (use .5123 for V-belts)
B = 1/2 groove angle
C = distance between shafts (in.)
D1 = sheave diameter
D2 = sheave diameter
L = Length
m' = mass/unit length of belt
Φ = Angle of contact
