Deflection Calculator for Triangular Shape Fixed End Single Concentrated Force Applied Beam Deflection
Beam Deflection, Stress, Strain Equations and Calculators
Beam Triangular Shape Deflection Equation Calculator with Variable Shape Fixed End Single Concentrated Force Applied
  • Cross Section: Rectangle: width y variable, depth h constant
  • Elevation: Rectangal
  • Plan: Triangle
Preview Calculator
Equations
Section Properties Triangle
Ss = b d2 / 24
I2 = b d3 / 36
y = 6 P x / ( h2 Ss )
b1 = 6 P l / ( h2 Ss )
Deflection at A:
f = ( 6 P / b1 E ) ( l / h )3
E = Modulus of Elasticity psi
(N/mm2)
P = Force lbf (N)
f = Deflection inches (mm)
Ss= Section Modulus in3 (mm3)
a, b, c, d, x, l = Some distance as indicated inches (mm)
  • Civil Engineering Formulas, Tyler G. Hicks, PE International Engineering Associates
