Related Resources: Electrical Design Engineering
Fundamentals of The Theory of Electricity
Electronics Design and Engineering
I.E. Tamm
689 Pages
Open: Fundamentals of The Theory of Electricity
Premium Membership Minimum Required
Introduction:
According to modern views, the atoms of all bodies are built of electrically charged particles-relatively light electrons charged negatively and relatively heavy atomic nuclei charged positively. Bodies that are neutral from an electrical viewpoint appear so to u~ only because the negative charge of their electrons equals the positive charge of the atomic nuclei in them. Hence, the influence of the opposite charges is mutually neutralized (at least at distances sufficiently great compared with the distance between the separate electric particles that are a part of a neutral body). The redistribution of electric charges and, particularly, an electric current are due to the motion of electric particles, mainly electrons and not atomic nuclei because an atom of a chemical element always includes a certain number of "outer'" electrons that are comparatively weakly bound to the massive central atomic nucleus and comparatively easily detached from it.
TOC
1.1. Coulomb's Law
1.2. Electric Field
1.3. Gauss's "Law
1.4. Electric Field of Charged Surfaces .
1.5. Conductors in an Electric Field . .
1.6. Sources of an Electric Field. Surface Divergence .....
1.7. Work of Electric Forces. Its Independence of the Shape of the Path.
Continuity of the Tangential Components of the Vector E
1.8. Potential of an Electrostatic Field .
1.9. Capacitance. Capacitors . . . . . . . .
1.10. Gradient of Electrostatic Potential. Lines of Force
1.11. Poisson and Laplace Equations . . . . .
1.12. Potential of Space and Surface Charges
1.13. Typical Problems of Electrostatics . . . . . . . . .
1.14. Electrical Double Layer .
1.15. Energy of Interaction of Electric Charges . . .
1.16. Energy of an Electric Field . . . . . . .
1.17. Ponderomotive Forces .
1.18. Determining the Ponderornotive Forces from the Expression for Energy ..
1.19. Instability of Electrical Systems. Constraints
2 Dielectrics
2.1. Dielectrics. Electric Moment and Potential of a Neutral Molecule. Polarization
of a Dielectric 108
2.2. Free and Bound Charges. Potential of an Electric Field When Dielectrics
Are Present. Dependence of Polarization on the Field . . . . . . .. 113
2.3. Electric Displacement Vector. Differential Equations of a Field in an
Arbi trary Medium. Induction Lines 117
2.4. Electric Field in a Homogeneous Dielectric 122
2.5. Direct Calculation of a Field When a Dielectric Is Present (in Very
Simple Cases) . . . . . . . . . . . . . . . . . . . . . . . . .. 125
2.6. Micro- and Macroscopic Values of Physical Quantities. . . . . . .. 130
2.7. Derivation of Equations for the Field in Dielectrics by Averaging the
Microscopic Field 134
2.8. Two Classes of Dielectrics. Quasi-Elastic Dipoles . . . . . . . . .. 137
2.9. Difference of the Field Acting on a Dipole from the Mean One . .. 139
2.10. Polarization of Dielectrics Whose Molecules Have a Constant Electric
Moment. Temperature Dependence of Permittivity. . . . . . . . .. 144
2.11. Energy of the Electric Field in Dielectrics. . . . . . . . . . . . .. 150
2.12. Energy Transformations Connected with the Polarization of Dielectrics.
Free Energy of an Electric Field. . . 154
2.13. Ponderomotive Forces in Dielectrics . 162
2.14. Reduction of Body Forces to Tensions 170
2.15. Stress Tensor of an Electric Field 175
3 Steady Electric Current . . . 184
3.1. Current in Metals. OhIU'S and Joule's Laws. Voltage . . . . . 184
3.2. Current Density. Differential Form of Ohm's and Joule's Laws . 188
3.3. Conditions of Steadiness of Currents. Continuity Equation. Current
Filaments . . . . . . . . . . . 191
3.4. Extraneous Electromotive Forces. Quasilinear Currents. Kirchhoff's
Second Law . . . . . . . . . . . . . . . . . . . . . . . . . .. 195
3.5. Conversion of Energy in a Current Circuit. Contact E.M.F.'s. . . .. 200
3.6. Fundamental Concepts of the Electron Theory of Metals. Tolman's
Experiments . . . . . . . . . . . . . . . . . . . . . . . . . .. 206
3.7. Electron Theory of Electrical Conductivity. Difficulties of the Classical
Theory. Sommerfeld's Theory . . . . . . . . . . . . . . .. 210
4 Ponderomotive Interaction of Steady Currents and Their Magnetic Field
(in the Absence of Magnetizing Media) . . . . . . . 218
4.1. The Magnetic Field of Currents . . . . . . . . . . . . . . . . .. 218
4.2. Interaction of Current Elemerits. The Electromagnetic Constant. . .. 222
4.3. Transition from Line Currents to Currents Having a Finite Cross Section. 226
4.4. Lorentz Force . . . . . . . . .. . . .. 229
4.5. Vector Potential of a Magnetic Field. . . . . . . . . . . . . . .. 234
4.6. Differential Equations of a Magnetic Field. Circulation of Magnetic Field
Intensity 239
4.7. Potential Fields and Solenoidal Fields. Comparison of Differential Equations
for an Electric and a Magnetic Fields 241
4.8. Boundary Conditions in the Magnetic Field of Currents. Surface Currents.
Surface Curl. Field of an Infinite Solenoid . . . . . . . . . . . .. 242
4.9. Ponderomotive Forces Acting on a Current Loop in a Magnetic Field.
Potential Function of a Current in an External Magnetic Field. . .. 248
4.10. Ponderomotive Interaction of Currents. Mutual Induction 252
4.11. Self-Inductance. Total Potential Function of a System of Currents. . . 1258
4.12. Magnetic Lines of Force . . . . . . . . . . . . . . . . . 262
4.13. Topology of a Vortex (Magnetic) Field. Conditional Barriers . 268
4.14. Magnetic Sheets. Their Equivalence' to Currents 272
4.15. Magnetic Moment of a Current. Elementary Currents and Magnetic
Dipoles 278
4.16. Direct Determination of the Field of Elementary Currents and the Forces
Acting on Them . . . . . . . . . . . . . . . . . . . . . . . .. 282
4.17. Evolution of Notions of the Nature of Magnetism. Spin of Electrons .. 290
4.18. Absolute (Gaussian) and Other Systems of Units, The Electromagnetic
Constant . . . . . . . . . . . . . 294
5 Magnetics (Magnetizable Media) 302
5.1. Magnetization of Magnetics. Molecular Currents and Conduction Currents 302
5.2. Vector Potential of a Magnetic Field in the Presence of Magnetics. Mean
Density of Space and Surface Molecular Currents 306
5.3. Differential Equations of the Macroscopic Magnetic Field in Magnetics.
Magnetic Field Intensity in Magnetics and Magnetic Induction Vector. 311
5.4. Dependence of Magnetization on Magnetic Field Intensity. Para-, Dia-,
and Ferromagnetics . . . . . . . . . . . . . . . . . . . . . . .. 314
5.5. Complete System of Equations for the Field of Steady Currents. Homogeneous
Magnetic Medium 317
5.6. Mechanical Forces Acting on Currents in a Magnetic Field. Interaction
of Currents. . . . . . . . . . . . . . . . . . . . . . . . . . .. 319
5.7. Ponderomotive Forces Acting on Magnetics in a Magnetic Field . . .. 323
5.8. Supplement to the Derivation of the Macroscopic Equations for a Magnetic
Field in Magnetics . . . . . . . . . . . . '. . . . . . . . 325
5.9. Mechanism of Magnetization of Magnetics. Larmor's Theorem . 329
5.10. Diamagnetism 335
5.11. Paramagnetism . . . . . . . . . . . . . . . . . . . . . 337
5.12. More Precise Definitions and Additions to the Theory of Magnetization.
The Part of Spin. Gyromagnetic Phenomena . . . . . . . . . . .. 34~
5.13. Ferromagnetism. Weiss Molecular Field 348
5.14. Equations of the Field in Idealized Ferromagnetics (Conventional Variant).
Permanent Magnets . . . . . . . . . . . . . . . . . . . . . . .. 356
5.15. Another Variant of the Equations of the Magnetic Field in Idealized
Ferromagnetics. The Equivalence of Electric Currents and Permanent
Magnets . . . . . . . . . . . . . . . . . . . . . . . . . . . .. 362
5.16. Ponderomotive Forces Acting on Permanent Magnets in an External
Magnetic Field 371
6 Quasistationary Electromagnetic Field 377
6.1. Induction of Currents in Moving Conductors . 377
6.2. Law of Electromagnetic Induction. Ohm's Law for Varying Currents 382
6.3. Quasistationary Currents. Differential Equations for Varying Currents.. 386
6.4. 'I'runsforuuuiuns of Energy in the Field of Varying Currents. Energy of
Magnetic Interaction of Currents. Lenz's Law. . . . . . . . . 389
6.5. Simple Applications of the Varying Current Theory. Transformer . .. 395
6.(,. Energy of a Magnetic Field. Energy Meaning of Inductances. . . .. 403
6.7. Transformation of Energy in the Magnetization of Para- and Diamagnetics.
Free Energy of a Magnetic Field. . . . . . . . . . . . . . . . .. 411
6.8. Determination of the Ponderomotive Forces of a Magnetic Field from
the Expression for Energy. . . . . , . 415
6.9. Stress Tensor of a Magnetic Field . . . . . . . . . . . . . . . .. 421
6.10. Vortices of an Electric Field 424
6.11. Dependence of Electric Voltage on Integration Path. Voltage of Alternating
Current . . . . . 427
6.12. Equation of Continuity . . . . . . . . . . . . . . . . . . . . .. 432
6.13. Displacement Currents 434
6.14. A Capacitor in the Circuit of a Quasistationary Current. Electric Oscillations
..... . . . . . . 441
6.15. The Skin Effect 446
7 Varying Electromagnetic Field in a Stationary Medium and Its Propagation.
Electromagnetic Waves 455
7.1. System of Maxwell's Equations for Macroscopic Electromagnetic Field. 455
7.2. Poynting's Theorem. Energy Flow . . . . . . . . . . . . . . . 461
7.3. Unambiguity of the Solutions of Maxwell's Equations . . . . . . .. 467
7.4. Differential Equations for the Potentials of an Electromagnetic Field 470
7.5. Solution of the Wave Equation and the d'Alembert Equation . . . 474
7.6. Delayed and Advanced Potentials. Gauge Invariance . . . . . . . 481
7.7. Velocity of Propagation of Electromagnetic Disturbances. Conditions
for a Quasistationary State 488
7.8. Oscillator. Delayed Potentials of an Oscillator Field 492
7.9. Field of an Oscillator. Its Radiation . . . . . . . . . . . . . 501
7.10. Electromagnetic Nature of Light. Plane Waves in a Dielectric 513
7.11. Reflection and Refraction of Plane Waves in Dielectrics . . . . . 518
7.12. Propagation of Waves in a Conducting Medium. Reflection of Light from
a Metal Surface 527
7.13. Light Pressure. Momentum of an Electromagnetic Field . . . . . .. 532
7.14. Electromagnetic Angular Momentum. A Particular Case of a Static Field. 539
7.15. Stress Tensor and Ponderomotive Forces of an Electromagnetic Field.. 543
7.16. An Example of Non-Quasistationary Currents: Waves along a Cable. .. 549
7.17. Approximate Theory of Fast-Varying Currents. "Telegraph Equation". 559
7.18. Free Energy of Ferromagnetics. Hysteresis 564
7.19. General Characteristic of the Theories of Short-Range and Long-Range
Interaction 571
8 Electromagnetic Phenomena in Slowly Moving Media 576
8.1. Differential Equations of a Field in Moving Media . . . . . . . .. 576
8.2. Convection Current. Polarization and Magnetization of Moving Media. 581
