Engineering An Illustrated Weekly Journal
Engineering, An Illustrated Weekly Journal
From July to December 1871
W.H. Maw
J. Dredge
Six Horse Traction Engine at the Wolverhamton Show
Open: Engineering, An Illustrated Weekly Journal
Minimum Premium Membership Required
Topics and Illustrations of historical interest of the era.
  • Bauschinger's Indicator Experiments on Locomotives
  • Six Horse Traction Engine at the Wolverhamton Show
  • Railway Bridge over The River Ohio at Louisville, USA
  • Goods Wagon for the Villa Maria & Rio Cuarto Railway
  • Stone Breaking Machine at Wolverhampton Show
  • Wood Working Machinery
  • Berrymans Water Level Regulator
  • Submarine Operations at Hellgate, New York
  • Horse Road Steamer
  • Compound Blowing Machines
  • Practical Electricity
  • Warrens Street Sweeping Machine
  • Compound Screw Engines
  • Boilers of H.M.S. Tenedos
  • Engines of the H.M.S. Tenedos
  • Robinsons Band Saw
  • Fisken's Steam Ploughing Tackle
  • Gramme's Magneto Electric Machine
  • Kirk's Refrigerating Machine
  • Press for Forming Blocks of Dust Coal
  • Hydraulic Pressure Crushing Mill
  • Norwich Sewerage Works Boilers and Plan Pumping Station
  • McEvoy's Time Fuse
  • Locking Apparatus for Facing Points Railway
  • Pumping Engines
  • Shaft Sinking Through Water-Bearing Sand Near Homberg
  • Coal Wagons
  • Evan's Vertical Mill
  • Dank's Rotary Puddling Furnace
  • Dredging Machinery
  • Piston Fitting Apparatus Used on The Kaiserin Railway
  • Bennett's System of Steam Cultivation
  • Gas Heated Boilers at The Tees Iron Works, Middlesbrough
  • Mackie's Logo Perforator
  • Swing Bridge over the River Parnitz Near Stettin
  • Apparatus for Heating the Tyres by Gas at the Metropolitans Railway Works
  • Gautreau's Dynametrical Governor
  • Milroy's Method of Constructing Foundations
  • Compound Surface Condensing Marine Engines
  • Nut Tapping Machine
  • Janicki's Floating Dock
  • Traction Engine Wheel
  • Variable Expansion Gear
  • Blast Pressure Regulator for Blowing Engines
  • Bessemer's Apparatus for Firing Heavy Ordnance
  • Winding Engines with Automatic Variable Expansion Gear
  • Register Weighting Machine
  • Dank's Squeezer for Puddled Balls
  • Guinotte's Expansion Gear
  • Moore and Head's Hoisting Pulley
  • Machinery for Bending and Flanging Plates
  • Baumann's Steam Donkey Pump for Traction Engines
  • Dredging Machine for the River Elbe
  • Morrisons Lock for Railway Carrige Doors
  • Twin Screw Engines for the Stevens Battery
  • Engines for Driving Centrifugal Drying Machine
  • Broadwell's Carriage for Multiple Guns
  • The Mont Cenis Tunnel Air Compressing Machinery at Bardonneche
  • The Hunton Governor
  • Dyer's Rail Gauge
  • Six Ton Shingling Hammer at the Britannia Iron Works, Middlebrough
  • Vertical Engine Fairlie Engines
  • Macpherson's Self Relieving Safety Valves
  • Shears and Engine for Forge train at the Britannia Works, Middlebrough
  • Siemans's Regenerative Furnace at the Britannia Works, Middlebrough
  • Standard Rail Sections for Light Railways
  • While's Blooming Mill at the Britannia Iron Works, Middlebrough
  • Scrap Shears the Britannia Iron Works, Middlebrough
  • Berryman's Steam Trap
  • Apparatus for Measuring the Radiant intensity transmitted by Flames
  • Rail Straightening Machine
  • Winding Engines at the Skelton Iron Mine, Saltburn by the Sea
  • Self Cleaning Corn Screen
  • Hydraulic Apparatus for Lifting Railway Carriages
  • High Pressure Marine Boiler
  • M'Carters Condenser at the City Saw Mills, Londonderry
  • Pichault's Diagrammagraphe
