Activated Sludge Wastewater Treatment Plants
Civil Engineering Resources
Unified Facilities Criteria
Open: Activated Sludge Wastewater Treatment Plants
Introduction to activated sludge wastewater treatment plants. In a conventional (plug-flow) activated sludge plant, the primary-treated wastewater and acclimated micro-organisms (activated sludge or biomass) are aerated in a basin or tank. After a sufficient aeration period, the flocculent activated sludge solids are separated from the wastewater in a secondary clarifier. The clarified wastewater flows forward for further treatment or discharge. A portion of the clarifier underflow sludge is returned to the aeration basin for mixing with the primary- treated influent to the basin and the remaining sludge is wasted to the sludge handling portion of the treatment plant.
  1. INTRODUCTION
  2. ACTIVATED SLUDGE PROCESSES
  3. CLOSED-LOOP REACTOR DESIGN CRITERIA
  4. EXAMPLE CALCULATIONS
  5. REFERENCES
  6. BIBLIOGRAPHY
