Engineers Edge
Spherical Cap Segment Volume and Area Equation and Calculator
Volume Equation and Calculation Menu
A spherical cap segment is the solid defined by cutting a sphere with a pair of parallel planes . It can be thought of as a spherical cap with the top truncated, and so it corresponds to a spherical frustum . The surface of the spherical segment (excluding the bases) is called spherical zone .
A = Area of spherical surface Segment
V = Volume of segment
Input Volume Data
Distance  c (in, mm) =
Height h (in, mm) =
Result
Volume V (in3, mm3) =
Input Area Data
Radius r  (in, mm) =
Height h (in, mm) =
Result
Area (in2, mm2) =
