True Position GD&T Tolerance Calculator
Tolerances, Engineering Design & Limits & Fits Resources
This calculator calculates position tolerances utilizing principles and concepts within ASME Y14.5-2018, ASME Y14.5-2009 ASME Y14.5M - 1994, as well as ISO 1101 Geometric Dimensioning and Tolerancing (GD&T).
Open True Postion Calculator
Negative Tolerance numbers indicate out of tolerance condition.
This GD&T true position calculator will convert coordinate measurements to position tolerances. Two (2) inputs are required, See the application illustration at bottom of page.
Offset (X) - This is the difference between the basic dimension (Drawing) and the actual measurement of the produced part.
Offset (Y) - This is the difference between the basic dimension (Drawing) and the actual measurement of the produced part.
Calculated (ACTUAL) True Position - The calculated positional tolerance diameter zone.
Allowable True Position - This is the true position tolerance defined/required (drawing) .
(+) Excess Tolerance - Additional available positional tolerance.
(-) Excess Tolerance - Allowed positional tolerance exceed by given measurements .
True position Calculator Declarations
Related Resources:
www.engineersedge.com
Advertising | Contact
