Bolt Nut Recommened Torque Table for SAE Grades
Design Resources | Torque Design Menu
Torque-Force Calculator | Torque Conversion Calculator
Torque Table
The following suggested tightening torques provide an excellent starting point for determining torque requirements. Remember, you may need to vary these numbers somewhat based on the individual joint or the amount of fastener lubrication.
This table is offered as the suggested maximum torque values for threaded products and is only a guide.
Torque Values = FT - lbs
Bolt Size Inches
Coarse Thread/ inch
SAE 0-1-2 74,000 psi Low Carbon Steel
SAE Grade 3 100,000 psi Med Carbon Steel
SAE Grade 5 120,000 psi Med. Carbon Heat T. Steel
SAE Grade 6 133,000 psi Med. Carbon Temp. Steel
SAE Grade 7 133,000 psi Med. Carbon Alloy Steel
SAE Grade 8 150,000 psi Med Carbon Alloy Steel
1/4
20
6
9
10
12.5
13
14
5/16
18
12
17
19
24
25
29
3/8
16
20
30
33
43
44
47
7/16
14
32
47
54
69
71
78
1/2
13
47
69
78
106
110
119
9/16
12
69
103
114
150
154
169
5/8
11
96
145
154
209
215
230
3/4
10
155
234
257
350
360
380
7/8
9
206
372
382
550
570
600
1
8
310
551
587
825
840
880
1-1/8
7
480
872
794
1304
1325
1430
1-1/4
7
675
1211
1105
1815
1825
1975
1-3/8
6
900
1624
1500
2434
2500
2650
1-1/2
6
1100
1943
1775
2913
3000
3200
1-5/8
5.5
1470
2660
2425
3985
4000
4400
1-3/4
5
1900
3463
3150
5189
5300
5650
1-7/8
5
2360
4695
4200
6980
7000
7600
2
4.5
2750
5427
4550
7491
7500
8200
