GD&T Two Mating Diameters Tolerance Analysis at MMC Calculator
Geometric Dimensioning & Tolerancing GD&T Training
GD&T Two Mating Diameters Tolerance Analysis at MMC Calculator | GD&T Training
This calculator calculates position tolerances utilizing principles and concepts withinASME Y14.5-2009 and ASME Y14.5M - 1994, Geometric Dimensioning and Tolerancing (GD&T).
For the equations behind this calculator, see:
"Geometric Boundaries"
Interpretation and Application of
Open
See application at bottom of page.
This calculator will calculate the required field for the given condition. Calculations assume a line-line case with "Clearance = 0" or will compensate for a static clearance as defined.
Note: All fields require an input except field being calculated.
Four (6) inputs are required.
See the application illustration at bottom of page.
Hole Diameter H2- This is the smallest hole (MMC) or similar other feature of size.
Hole Tolerance Tol_h - This is the positional tolerance for the given feature of size.
Hole Size (Datum) H1 - This is the smallest hole (MMC) for the given feature of size.
Shaft Diameter D2- This is the largest size (MMC) of the shaft or other feature of size.
Shaft Tolerance Tol_d - This is the positional tolerance for the given feature of size.
Shaft Size (Datum) D1 - This is the largest shaft (MMC) for the given feature of size.
Clearance C - This is additional clearance required for design when line-line worst case condition is
not desired.
Open
Related Resources:
