Spring Material and Types Data Review
Spring Design Menu
This table details engineeriong properties of common spring materials as well as some alloys for design material selection application. The specifications indicated are current at the time of publication.
See Calculator Page for Spring Design Calculators!
Types of Springs:
Compression Spring is an open-coil, helical spring that offer resistance to compressive loading.
Extension Spring is a close-coiled helical spring that offers resistance to a pulling force.
Torsion Spring exert pressure along a path which is a circular arc, or, in other words, providing torque.  Sometimes these springs are called torsion springs, motors springs, power springs.
Related resources:
Common Spring Materials and Engineering Properties
Spring
Material
Materials Specification
Density (lb/in3)
Minimum Tensile Strength
(psi x 103)
Modulus Elasticity (E)
(psi x 106)
Modulus Torsion (G)
(psi x 106)
Maximum Operating Temperature
Application
Beryllium Copper
ASTM B197
0.298
150 - 230
18.5
7.0
400 °F
Good corrosion resistance and electrical conductivity. Good physical strength.
Chrome Vanadium
ASTM A231
0.284
190 - 300
30.0
11.5
425 °F
Used for shock loads and moderately elevated temperatures.
Elgiloy
AMS 5833
270 - 330
32.0
12.0
250 °F
Excellent corrosion resistance.
Hard Drawn MB
ASTM A227
0.284
Class I: 147 - 283
Class II: 171 - 324
30.0
11.5
250 °F
Typical stress applications. Can be electroplated.
Hastelloy (C276)
ASTM B574
100 - 200
30.7
11.8
700 °F
High corrosion resistance.
Inconel 600
AMS B166
0.304
100 - 230
31.0
11.0
700 °F
Corrosion resistance at moderately elevated temperature.
Inconel 718
AMS B637
0.298
210 - 250
29.0
11.2
1100 °F
Good corrosion resistance at moderately elevated temperature.
Inconel X750
AMS 5698 / 5699
0.298
No. 1 Temper: 155 Min
Spring Temper: 190 - 230
31.0
12.0
750 - 1100 °F
Monel 400
AMS 7233
0.319
145 - 180
26.0
9.5
450 °F
Monel K 500
QQ-N-286
0.306
160 - 200
26.0
9.5
550 °F
Excellent corrosion resistance at moderately elevated temperature.
NiSpan C
AMS 5225
0.294
150 - 190
24.0 - 29.0
9.0 - 10.0
150 °F
Constant modulus alloy.
Music Wire
ASTM A228
0.284
230 - 399
30.0
12 (up to 0.100")
11.75 (over 0.100")
250 °F
Good surface finish.
Oil Tempered MB
ASTM A229
0.284
Class I: 165 - 293
Class II: 191 - 324
30.0
11.5
250 °F
General purpose spring wire can be heat treated.
Oil Tempered Chrome Silicon
ASTM A401
0.284
235 - 300
30.0
11.5
475 °F
Shock loads and moderately elevated temperatures.
Phosphor Bronze
ASTM B159
0.320
105 - 145
15.0
6.25
200 °F
Cold drawn. Good corrosion resistance and electrical conductivity.
Stainless Steel 302/304
ASTM A313
0.286
125 - 325
28.0
10.0
550 °F
Cold drawn general purpose corrosion and heat resistant.
Stainless Steel 316
ASTM A313
0.286
110 - 245
28.0
10.0
550 °F
Heat resistant and better corrosion resistance than 302.
Stainless Steel 17-7 PH
AMS 5678
0.282
235 - 335
29.5
11.0
650 °F
High strength and general purpose corrosion resistance.
