Plastic Snap Fit Tapered Arm Dynamic Strain Equation Calculator
Plastics Design and Engineering Resources
This calculator requires a java - enabled browser
Open: Snap Fit Tapered Arm Design Calculator
The following are definitions for the elements:This calculator calculates the Dynamic Strain of a tapered cantilevered flexing finger typically used in plastic snap fit type designs.
strain against material
Y =[ 2 ε L2 ] / [ 3 ho]
ε = Dynamic Strain (in/in, mm/mm)
Y = Maximum deflection (in, mm)
ho = Thickness at base of finger (in, mm)
L = Length of finger (in, mm)
Check calculated strain against material mechanical specifications.
K = hL / ho CHART K = hL / ho CHART
Proportioned Constant K
Open: Snap Fit Tapered Arm Design Equation and Calculator
Contribute Article
