Reverse Engineering Review
Reverse Parts and Components
Engineering Application and Design
In general, Reverse engineering (RE) is the process of taking something (a device, component, an electrical component, a software program, etc.) apart and analyzing its workings or geometry in detail, usually with the intention to construct a new device, component or program that does the same thing without actually copying anything from the original.
Reverse engineering is a often used by military, in order to copy other nations' technology, parts of which have been obtained by intelligence operations. It was often used during the Second World War and Cold War.
Reverse engineering software or hardware systems for the purposes of interoperability, for example in order to support undocumented file formats or hardware peripherals, is mostly believed to be legal, though patent owners often aggressively pursue their patents.
Coordinate-measuring machines (CMM) can be used to digitize a component and the information can be utilized in computer-aided modeling. New and improved techniques in reverse engineering include 3D laser scanning which, as the name implies, uses laser beams to scan across the surface of components of any shape and display the results in real time.
